Reply
Highlighted
Problem with phone service
I signed up to Public Mobile today. I got my new phone number and signed up for $20 unlimited province-wide talk.
However, I cannot receive incoming calls. Also, if I make an out going call, I get the message that long distance charges may apply, even if the call took place in the same province.
Please help
Thanks
Accepted Solutions
Highlighted
Re: Problem with phone service
Please help
Thanks
If nothing helped and the port is not finished after 4 hours you need to write a message to the moderator...https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and explain what happened. Waiting time is few hours to 2 days..patience..
All Replies
Highlighted
@Air36Try restarting your phone, if that doesn't work go into your account report your phone as lost, log out, wait 5 minutes, log back in and report it found, then restart your phone.
If you are moving your phone number from another provider try your old SIM, the port may not have gone through yet.
If you are getting a long distance warning try dialing a 1 before the number.
Highlighted
@Air36
Don't worry, you will not get charged extra for long distance since Public mobile is prepaid.  The call just will not connect.  No surprise charges or overages with PM.
You may want to try the lost/stolen phone trick to reset your SIM card/plan.  It seems to work with various account issues.
To report your phone stolen.  Login to your account.  Choose Plans and Add-onstab. Then choose Lost/Stolen Phone tab.  The choose Suspend Service tab.  Logout.  Wait few minutes.  Login in and report your phone found.
If that does not work, you may need to contact moderator.
Highlighted
Please help
Thanks
Highlighted
Thanks everyone for trying to help me. I contacted a moderator.
