Porting number from Koodo
evad
I just activated a new number as per instructions for those porting from Koodo and sent the moderator team a message to port my number. How long does it take? I don't want to be paying both Koodo and PM while both these accounts are active.
TylerDLR
Can you please type in English? With proper spelling??
bilal684
Thanks for the info @OP
evad
Confirming that I was able to do it myself through self serve!
evad
Wait so if I have Koodo post-paid than I can just do it myself?
will13am
It's probably as fast as your phone will reboot.  Porting from sister companies is instantaneous.
mimmo
koodo prepaid is th only one thar requires special atttention.
you ca go ito selfserve and select change number.. f you do this ake sure you only use the koodo name on accont an koodo accont number)
