Porting from WIND/Freedom Mobile
Vbee
 I have been having trouble porting my old number to this service and it turns out I gave the wrong PIN for that account when doing the porting, my question is how can I go through the porting process again? When I try it says something along the lines of being Invalid number.
Vbee
@Luddite
 No luck at the moment, I've sent a PM to a mod so it's time to play the waiting game. Thanks for all the info though!
It's unlikely you port-in will go forward, but give it 6 hours while rebooting your phone now and then.
If no success after 6 hours, try this:
http://productioncommunity.publicmobile.ca/t5/Discussions/How-I-fixed-porting-my-mobile-number-and-p....
If that fails you need to follow this procedure after taking your patience pill as response may be a week:
http://productioncommunity.publicmobile.ca/t5/Announcements/Information-required-before-sending-a-me....
Fortunately your Wind SIM is still functional and you can just keep using it. Do not cancel your Wind account that will happen automatically.
Vbee
This is the text I get when I try to do that"
We are experiencing difficulties in processing this request. Please contact Public Mobile for additional assistance.
". Additonal info I forgot to list is that I can call and use data from the Public Mobile sim, just can't recieve calls.
Pier
@Vbee
Go to your self serve service and then click on change number. From there you can port your number out.
