12-09-2019 09:51 AM - edited 01-05-2022 08:26 AM
I just activated PM sim online with porting my fongo number yesterday. I can make outgoing calls with my old number and text as well. But when try to call the old number it directly to my old voicemail. Now is almost 20 hours after activating. Any help would much appreciated!
01-06-2020 02:37 AM
Send private message to moderator
01-06-2020 02:37 AM
Send private message to moderatoe
01-06-2020 12:22 AM
@Iamjack19 hello, I am having the same problem! how long did it take until it worked out for you?
12-09-2019 10:15 AM
Thank you very much!
12-09-2019 10:14 AM
Thanks a lot!
12-09-2019 09:58 AM - edited 12-09-2019 09:59 AM
Landlines take up to 7 business days for the port to complete.
You will know it's complete once your Fongo service stops working and your Fongo account closes.
In the meantime, if you receive a text from Public Mobile regarding the port, it means there was a problem and you need to contact Moderators for their help to complete the port.
12-09-2019 09:57 AM
@Iamjack19, number ports from VOIP providers take a very long time just like with land lines. I would give it another day or two. In the mean time keep using the old service until it stops working which is a proxy that the port has completed. Anyway, if the port is still not completed in another day or two, you will need to contact the moderator team so that they can investigate and take additional action. The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team.
12-09-2019 09:57 AM
It can take up to a week to port a Voip number to PM.
