Can somebody tell me if it is possible to port a number from Rogers Pay As You Go plan to PM ?
Thanks.
should not be an issue
Keep the porting information simple and concise. Just need the account holder name, account number and phone number. Usually don't need extra information such as PIN, IME, etc.
Make sure that your Roger's account is active prior to porting.
Great. Thanks for confirming it.
it should work, give it a shot, if ur having trouble report back. Porting is the easiest thing to do btw. So u should know fairly quickly if its working
I am trying to port a Rogers Pay as you go number. There is no account number and i haven't been able to set up the new account on Public Mobility. Texts work but not phone calls. I received a text from Public Mobility saying I need to input account number but I do not have an account number. Can someone help?
You'll have a much better chance to resolve your question if you start a new thread.
Thanks. How do i start a new thread.
All you need to do is to pick a line with random # and send a port request just like this:
1-Go to publicmobile.ca and then click My account.
2-Log in to your self-serve account.
3-Select Plan and Add-ons tab from Overview page.
4-Select Change Phone Number from Plan Summary page.
5-Transfer # IN
Don't forget that the line need to be active to port it in
-PM Team
