Reply
Highlighted
Ported number not receiving phone calls
I ported my cell phone number the other day, but i cannot receive calls, they go right to voice mail (which I'm also not receiving).
In self-serve i confirmed under plans & addons that my number appears as the ported number, so i'm guessing it went through, but what else can I do?
Accepted Solutions
Highlighted
Re: Ported number not receiving phone calls
The self-serve page will show your ported phone number as soon as you make the request.  It is not an indication that your number has been ported over.  The first thing you should check is if that voicemail box that you are hearing is in fact the one that you setup at the old carrier.  If that is the case, your phone number has not yet been transfered.
All Replies
Highlighted
Highlighted
@NotaModerator, You should contact the moderator team, as there could be a problem with the port.  Are you sure there is no auto forward 9to voicemail) set up on your phone.  Also are you able to receive texts?
Click here to send them a private message.
Information regarding the moderators team can be found by following this link.
Highlighted
Sounds like your port is stuck and I bet if you insert your old SIM you will get all of your Voicemails through that line and it will still be active.  You will need to contact the Moderators by private message and you can do that by clicking on the link in my signature.
* I am happy to help, but I am not a MOD please do not include any personal info in a private message to me, click the "?" in the bottom right to create a trouble ticket *
Highlighted
I believe this must be the case then, as i'm hearing the old voice mail greeting.  I'll try the mods, thanks again.
Highlighted
I had the exactly the same problem when I switched my wife's Fido to PM 30 days plan yesterday.  It went to Fido's voice mail box. I was about to get panicy, then I got a SMS from PM said the porting was successful about 15 minutes later.  Just relax and wait for the SMS.
Highlighted
This means that all your incoming phone calls are still going to your old provider.  You should be able to still use the service at the old provider until the phone number is transfered.
Before contacting a moderator, I would make sure you have the correct account number from your old provider.  If the Public Mobile moderators need to resubmit the phone number transfer request, you'll need to be able to provide such information about your old provider's account.
Wireless to wireless provider number porting is supposed to be completed within 2.5 hours. Since you are saying that you made the phone number transfer request on a different day in the past, it's likely that you'll have to try to the number port again.  Don't try to do this yourself, but make sure you get a moderator to  help you.
Highlighted
Hello. I signed up with public mobile 12 days ago and have not been able to receive calls. Most text messages seem to work, I can make calls just not incoming. It says the number you have reached is not in service. Can this please be fixed.
Highlighted
hi you probably have an incomplete port. only mods can help.  please message them and provide the info below:
How can you get help with your account, activation, or service?
In your message please include:
  • PM Phone Number, 4 digit PIN, Account email address, Detailed explanation of your issue
If you have a Porting issue, please also include:
  • The number you want to port, PM sim number, old account number, old account name exacly as on bill
Don't know your pin?--provide any 3 of the following:
  • Complete mailing address, Email address, Alternate phone number, Date of birth, Last top up date & amount
How long until they reply?:
  • Office Hours: Mon-Fri 9am to 9pm, and Sat-Sun 9am to 7:30pm [Totonto Time] from 9am to 7:30pm [Totonto Time].
  • Messages are replied to during business hours and in the order they are received
  • Typical response time is between 1-3 hours, depending on message queue, but can be up to 48 hours.
  • There is no need to send multiple messages.
Additional Useful Information:
  • Search PM-GUIDE (remove "-" during the search) to find some informative posts and answers to many common questions about Public Mobile
Highlighted
You can try the following steps:
-Go into your phone's settings and under Cellular Settings, manually choose Public Mobile as your Network operator
-If that doesn't work, reboot your phone
-You can also power off your phone and remove your SIM.  Re-insert and power on.
If that doesn't work, you can send a private message to a Moderator_Team and ask them to look at your account.
