05-07-2019 11:20 AM - edited 01-05-2022 04:48 AM
05-07-2019 11:47 AM
@yodachin wrote:Can anybody @Moderator_Team reply to my private massage to port number from koodo prepaid?
Thanks
@yodachin The moderator will respond eventually you just need to be patient. In the meantime just keep using your Koodo prepaid sim until it stops working. Once that happens it means that the port is completed and you can start using your PM sim for call/texts/data depending on what plan you have selected.
05-07-2019 11:41 AM
@yodachin , moderator team response time is longer then normal due to recent and ongoing impact to numerous customer accounts. Rest assured your request will be investigated.
05-07-2019 11:40 AM
Thanks
You need to send a private message to moderator if you have not done so. Otherwise, wait for moderatore response to the request. Moderator wait time is 2 - 3 days.
05-07-2019 11:27 AM
When did you send it in? Only wait for it.
