Reply
Highlighted
Picture Message
Can I send picture messages even if I don't have Data plan. For example if I have $25 plan (Unlimited Province wide calling + Unlimited International Text ) but not data ?
Accepted Solutions
Highlighted
Re: Picture Message
You sure can...   $25 30-days
  • UNLIMITED  Talk Province-wide²
  • UNLIMITED International Text and Picture Messaging
VOICEMAIL & Call Display
All Replies
Highlighted
Re: Picture Message
Highlighted
Re: Picture Message
Yes, MMS(picture message) is included even your plan does not have data.  For an example, the $10 50/50 plan can send and receive MMS message as long as you enable data on your phone to receive/send MMS.  Since PM plans are prepaid, there is no risk of being charge on pay-per-use basis.
Highlighted
Re: Picture Message
@Sharry19In order to get it to work, you must enable data on your phone, and be properly connected to the Public Mobile data network.  You WILL NOT be charged for any data!
Highlighted
Re: Picture Message
@Sharry19, as the other's said, yes you can send picture messages with the $25 dollar plan, just make sure your data service on your phone is on, it won't send the message if it's not on.  Also, if you're on WIFI the message won't be sent either.  For some reason some people forget that.  Lastly, at least for me, if my data and WIFI are both on at the same time, the picture message does not get sent, I believe the WIFI signal takes priority, so I assume that's the same for other devices as well, so you may want to keep that in mind.
