Reply
Highlighted
Phones that work with network
Does Galaxy A71 work with this network.
Highlighted
Re: Phones that work with network
Yes it does. Make sure it's unlocked. Don't forget to use a referral code for a$10 signup bonus.
Highlighted
@Gurchetankang
Yes, it will work with Public mobile.
Here are your phones specs:
https://www.gsmarena.com/samsung_galaxy_a71-9995.php
3G bandsHSDPA 850 / 900 / 1900 / 2100
 HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
4G bands1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 20, 28, 38, 40, 41, 66
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
Highlighted
As @Jb456 says it will work. Welcome to PM.  Stay safe.
Here's 4 articles on activation and porting and the Refer a friend reward  if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
And once you activate your SIM card. Insert your SIM card and reset your network settings
Reset Network Settings SAMSUNG Galaxy A71
  1. Firstly, choose Settings.
  2. Secondly, go to General management.
  3. After that select Reset and Reset Network Settings.
  4. At the end choose Reset Settings and Reset.
  5. Well done!
Restart your phone and re- enter your WiFi if applicable. You should be set to go.
Highlighted
@Gurchetankang  If you go here,
https://www.publicmobile.ca/en/qc/get-started
you can check ALL the phones that work on the Public Mobile network!
Highlighted
@pharaohpeter  Take note that the compatibility phone check does not list "all" phones. That link is manually updated by Public Mobile.
Many newer phones (like ops) is not listed until PM updates the list.
As long as the phone matches public mobiles frequency it will work.
Highlighted
@Jb456For 4G to be able to function on Public Mobile, does the phone have to have ALL those 4G frequencies? Or will it work if you have only one of the frequencies?
Highlighted
Yes but make sure the model is a Canadian one (model SM-A715W). Samsung also produces international versions which may not be fully compatible but will still do the job.
Cheers.
Highlighted
Thanks for your help.
Highlighted
yes absolutely works if not blacklisted or locked in another country. For example i tried my sim card in sprint carrier locked phone(American version) it was not working.
It depends upon your device if its factory unlocked.
