Phone
Rogieez94
I tried to use my other samsung phone and it was from telus I tried my public mobile sim card and it didnt let me have wifi. I just had calling and texting
GinYVR
@Rogieez94Can you verify if your (or any) Telus card is back in the Samsung phone you get wifi? Just want to verify it is a carrier customization issue. Was your Samsung phone a prepaid phone?
If so, I would suggest you backup your data, then go to your nearest corner cell phone store and ask them to flash the original factory firmware for you. That should remove gotchas like that.
Before your threads get merged...
Using cell data requires correct Access Point Name (APN) settings.
Find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Wi-Fi isn't carrier dependent. What model is your phone?
hairbag1
Wifi isn't provided by Public Mobile. You need to make sure your phone is setup to recieve the your wifi signal.
