Reply
Highlighted
Phone number
Just activated with my land line number & got the wrong one. Any way to fix?
Highlighted
Re: Phone number
What do you mean got the wrong one?
Did you port your land line number to public mobile?
Highlighted
Re: Phone number
Just start another port from your selfserve
https://selfserve.publicmobile.ca/Overview/ChangeNumber/
Highlighted
Re: Phone number
Yes I ported Land Line. but ended up with a number that is a combination of my land line & my alternate phone number.
Highlighted
Re: Phone number
@nixy If you port in your other landline number you will lose the one already ported to PM.
Highlighted
Re: Phone number
Contact moderators.
Or private message them at link below
You can try calling Telus porting team to as they do Public Mobile ports since Telus owns Public Mobile.
1-877-868-3587
Highlighted
Re: Phone number
Hi @nixy
If you mistyped you can just cancel that port by initiating the new one
Sing in and click on the link above and you'll be able to choose transfer number and fill in the form.
Note landline can take days to transfer, use your landline until the port completes
Highlighted
Re: Phone number
Sign into your account and click on "change number" button.  Follow the steps to change it to the one you want.
Highlighted
Re: Phone number
@nixy  Submit a ticket and ask PM to change the number and resubmit the port.
To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking the icon below:
If you are still having problems contacting Public Mobile then click here. The link  sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Highlighted
Re: Phone number
@nixy Try to login to your account. If possible, you can try the port-in again via the Change Number page as suggested earlier.
If you cannot, you must submit a ticket as suggested earlier.
Once you get the account sorted be prepared for at least a week for the port-in to finish. Until then your old account must be paid up and active. You will have to answer incoming calls on your landline, even though you will be able to make outgoing calls on your cellphone.
>>> ALERT: I am not a moderator. Je ne suis pas un moderateur.
