Phone always goes straight to voicemail.. data does not work. Need a moderator to help please
rads
90% of incoming calls go straight to voicemail. Paying for data services and has never worked.
Please help.
rads
Thank you Luddite..
All settings have been checked. Even bought a new phone still no luck.
@rads Check you have not accidently blocked incoming calls, or turned on "Do Not Disturb".
Read through this article to troubleshoot your data issues: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-up-Data-APN-on-your-phone/ta-p.... Login to your account and see whether data still shows under Plans and add-ons. If not there, you've used all the data allowance or it's not part of your plan.
For more detailed help tell us make/model of your phone.
matbasm
Hi @rads, You might get a quicker respons from the mods if you send a private message to the moderator team.
Click here to send them a private message.
Information regarding the moderators team can be found by following this link.
