02-23-2021 10:06 PM - edited 01-05-2022 05:24 PM
My I phone 7 does not ring even though it is not on silent mode setting . It goes straight to Voicemail.
My wife has the same monthly plan and reception and no problems at all
Any help appreciated. Thx
02-24-2021 04:16 AM
Sounds like a provisioning issue....did it happen after you renewed your plan? If @softech 's tip doesn't work you have 2 options.....
Suspend your service via lost/stolen. Log out/in. Resume. Log out and reboot. Test. But this method may cause your rewards to not apply during renewal requiring you to contact the moderators to have the rewards applied manually after your next renewal.
Or contact the moderators and ask them to reprovision your sim card. Choice is yours.....
02-23-2021 11:46 PM
Do you have any call blocks in place or Do Not Disturb turned on?
02-23-2021 10:51 PM
@SW1954 check the setting if Call Forwarding is disabled. Enable Silent Unknown Callers.
02-23-2021 10:21 PM - edited 02-23-2021 10:26 PM
Try a network reset.
Make sure you don't have the contact blocked or Do Not Disturb enabled.
Do Not Disturb may be different from Silent settings. On my device, I have both options.
02-23-2021 10:21 PM
I had that issues once, too.. My outgoing call and data no issue, just incoming
I tried reboot and didn't work
In the end, I powered off my phone, took the SIM out, wipe it clean, wait for a min and then I put it back and power it back on and viola, issue resolved.
hope this helps
02-23-2021 10:08 PM - edited 02-23-2021 10:08 PM
@SW1954 wrote:My I phone 7 does not ring even though it is not on silent mode setting . It goes straight to Voicemail.
@SW1954 ,
If you just ported your phone number from another cell provider it could take a few hours to complete the port. Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
If you ported from a landline it could take up to 7 days to complete.
Make sure you do not cancel your previous provider's services until the port is complete.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
If you did not just port a number over try one or more of the below:
*try your SIM in your wife's phone.
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reboot your phone again
