08-22-2020 03:27 PM - edited 01-05-2022 12:53 PM
I thought I entered the number to be transferred as xxxxxxxxxx. However, the summary of transfers shows xxxxxxxxxxxx. I want the first number - how do I make the change?
edited by computergeek541: phone number removed
08-22-2020 03:39 PM - edited 08-22-2020 03:40 PM
@Cola wrote:I thought I entered the number to be transferred as xxxxxxxxx. However, the summary of transfers shows xxxxxx I want the first number - how do I make the change?
@Cola contact a moderator for assistance to contact a moderator click on the ? Bottom right hand corner Ask Simon to speak to a human this will help create a ticket to speak to a moderator mention incorrect number ported check the envelope top right corner for a reply response time is 2 to 48 hours
08-22-2020 03:32 PM
@Cola use the 3 dots on the top right of your post to remove your personal information from the post. It's a public forum. Stay safe.
08-22-2020 03:28 PM - edited 08-22-2020 03:42 PM
@Cola wrote:I thought I entered the number to be transferred as . However, the summary of transfers shows . I want the first number - how do I make the change?
@Cola try contacting a moderator you can do so by clicking the question mark at the lower right corner,to avoid going around in circles with Simon say that you want a human to speak to, a ticket will then be generated briefly mention your issue, you should get a response between 2 to 48 hours a reply should show up in your little envelope in the top right corner
