Numerous problems on startup
halda
Signed up for 500MB +500MB $25 plan at London Drugs and then found out I was put on other, less desirable $25 plan.  Used site to change back to plan I wanted.  My phone works but I can only recieve text, not send, and I have no connection to network.  Phone is unlocked and is turned on for using data.  Have seen some reference to porting which I do not understand or know if it refers to my problem.  Ideas?
12 REPLIES 12
halda
Phone says it is hooked up to Public Mobile.  It does not have an APN configured which might be a  problem.  I have tried one set of instructions to create one which didn't work so I will keep  trying for this.  Am I right?  Do I need an APN on my phone?
Dogbert
Here's a few things to try:
1. Reboot your phone (power off & on).
2. Check that your phone says that you're connected to PM.
For Android:
  • open your device's settings app
  • open "Network & Internet"
  • open "Mobile Network"
  • open "Settings"
If not, try resetting to see if it picks up the PM network.
3. If that fails, something went wrong in the porting process and you should send a private message to a mod.
cavemantoronto
You told self serve to do the change right away?  If you did that, you just paid $25 more.
halda
Thanks, will try them.
Jessica_T
@halda
@halda wrote:
Always texted with no data before.
Your phone might not have fully activated after porting using this link send them a message so they can fix it
Jessica_T
@halda
@halda wrote:
Account disabled
The moderator team can be reached via private message using this link.  Send them a message
halda
halda
Account disabled
@halda wrote:
Kept my old number, changed April 3, disconnected from Virgin immediatley.  Then found out my phone was locked and that took a while to sort out.
@halda  If you keep your old number, it means you ported in from virgin. April 3rd is long enough time to have porting process completed successfully.
Try sticking in your old virgin sim card, is it still working or has it stopped? When you say disconnected from virgin, is that you sticking in the PM sim, or the account being disabled?
halda
RobertQc
@halda  Did you choose a new number or did you bring your old number from another company over? What day did you sign up at london drugs, and when did you change your plan to the new one? Did you do a "change plan now" or "change plan at renewal" ?
RobertQc
@halda  If you have no connection to network, how do you receive text? Turned on for data using Wifi? Are you using imessage? What about calls? You are not on public mobile network?
