Note: PM charge for airtime in voicemail
danlee
Whoever said that PM do not charge airtime for whoever leaving a message in your voicemail is not true, I just checked and found out that PM do charge airtime for people leaving a message in your voicemail.
** This does not applies for PM customers who are on unlimited call plan.
23 REPLIES 23
Brooke_C
Retraité / Retired
Retraité / Retired
Hey @Luddite
Retrieving or leaving voicemail messages will use plan minutes. To make sure this is super clear, we will be adding it to the table of what does and doesn't use minutes in the Limited Talk and Text  PlanCommunity Announcement. Appreciate you bringing this to my attention.
danlee
You can change your name by accessing into your account not the community account.  I did that before, just click Account, enter your email address and password than go to profile under account name to edit and change.
danlee
I just email to PM. Thanks jp
danlee
Well, i sure hope you are right but i checked again on my usage breakdown.  I still do not see me using 8 min... And PM charges me 8 mins... in fact i only uses 2 call out... But was charge mysteriously voicemail (that i suppose called to voicemail which i did not)...
The break down show 5 min... But the usage state is 8 min.
Only think i could think of is "voicemail airtime" is charge on my usage...
And no i did not access voicemail and still hope PM can make it easier to disable voicemail
jp2
Try using a different browser or incognito mode on chrome.
If that doesn't work private message the mods
Mooremarco56
i am trying to chnage teh anme on my accoutn to my name my mom dont wnat nothign to do with public mobile and it giving this error
There was an error in processing your request. Please ensure you have entered a valid Alternate Phone Number. and my numebr is vaild
Acekiller
you can access your mailbox through another phone though by dialing your own number. doesn't use up the airtime via this.
@LEGO
Calls to voice mail = when YOU call your own voicemail (to retrieve the message)
This was put in to prevent obvious abuse (eg never answer phone, retreive message, use no minutes)
@LEGO wrote:
@danlee If you look at $10 / 30-days plan description, you will see that it says: Calls to voicemail will deduct from in-plan minutes.
I have said before, if you want to avoid being charged for people calling and leaving messages OR you checking your messages to disable Voicemail completely!
kav2001c
@danleePublic does not charge airtime when someone leaves you a message
I have personally tested this now
ONLY when you retrieve the message
Also does not use minutes when you call forward
In both cases it will show minutes in use history but going to front page you can see the minutes used X/50
LEGO
@Acekiller wrote:
There was a question regarding whether Long-Distance minutes are charged when checking for VM. Perhaps that got lost in translation.
This plan is Canada-wide Talk, so Long-Distance minutes not relevant in this case. Woman Wink
Acekiller
LEGO
@danlee I have disabled Voicemail on mine (Android) phone to stop Spam calls! I am also using a Call Blocker and created a White List for “safe” people.
Are you using Android phone?
danlee
My post was to make new PM have a better understanding although it is nice to have community poster but not all the replies are true to say.  And yes, you did mention to try to disable but it is not as simple and easy as you say, you just can't simply disable that voicemail feature
@Luddite wrote:
 My understanding is quite clear: no airtime charges for call forwarding nor leaving a voicemail, but charges for listening to voicemail from your cell phone. The fact that usage shows in history does not necessarily mean there is a charge.
Re-reading this not sure if Luddite meant a caller leaving you a voicemail or you calling and leaving a message.
Wouldn't leaving a voicemail be considered in the making of a call.  I know when I was on a minute based plan as soon as an answering machine or voicemail picked up the call it was a completed call and you would be charged usage on that.  Now this was not with PM but with Telus and other providers.
danlee
Well, like I said, it only applies for those "limited call plan"... and yes, I checked my usage breakdown and they stated the "voicemail number" as an airtime so PM does charge airtime when someone leave you a message in your voicemail regardless you check it on your cellphone or not.
danlee
Like I mentioned, I ever asked a question and someone ever replied that Voicemail was "NOT" counted towards airtime and I am trying to clear up any confusion as it does.  And I did not state it was from PM post.
Hopefully the moderators, or @Brooke_C,  will update us. My understanding is quite clear: no airtime charges for call forwarding nor leaving a voicemail, but charges for listening to voicemail from your cell phone. The fact that usage shows in history does not necessarily mean there is a charge.
ShawnC13
So you are saying you are being charge minutes for someone leaving you a voicemail even if you don't check it?  I don't understand how that is possible, but if you do check your voicemail yes that will consume minutes.  Leaving a voicemail for a call you have made will also consume minutes.
@matbasm wrote:
@will13am, Any chance we can get a mod to update the original post to add 'leaving voicemail' to the FAQ , under what does and does not use my minutes?
Any one of us can comment on the announcement thread and bring up anomalies.  The oracles don't have special access in this case.
matbasm
will13am
I will just add that the usage counter is the same for unlimited plans but we don't care as it doesn't matter.  We can never run out of usage.
matbasm
@danlee, where did you see that it says that the time used when someone leaves you a message is not counted towards your minutes.  I checked the original post (here), and I see no mention that leaving a voicemail is excluded from being counted.
LEGO
