02-23-2021 09:09 PM - edited 01-05-2022 05:24 PM
Hello, I have transferred from Fido to Public mob yesterday. Now I can only call others, but cannot get any call. How can I fix it. Thank you
02-24-2021 12:21 AM
@Nazmul wrote:My problem has resolved. Now I can get calls.
Thanks
Hi @Nazmul so nice to hear that your problem is resolved.
It would be nice if you go to the reply that helped you the most and click ‘Accept as Solution’ on the response. It helps people find answers more quickly and communicates your appreciation to the people who helped you. Thanks in advance.
Welcome to Public Mobile
RosieR
02-23-2021 10:01 PM
Thanks
02-23-2021 09:40 PM - last edited on 10-05-2021 08:24 AM by Dunkman
Call the porting line which deals with failed ports.
The porting helpline is 1-x. (NOTE -- It's not available for any other account related inquiries.)
02-23-2021 09:23 PM
@Nazmul : user computergeek541 has supplied that earlier. Put your Fido SIM back in. Incoming will work fine. Then eventually you'll get the confirmation. Confirm. When the Fido SIM stops working then put in the new SIM and you should be good to go.
02-23-2021 09:22 PM
@Nazmul wrote:@Anonymous : Fido just told me I have to request Public mob to send Fido a transfer request. Then Fido will send me msg to accept the transfer. How can send request to Public mob to send the transfer req to fido?
Thanks
Please folow the instructions provided earlier to open a ticket.
02-23-2021 09:21 PM
@bolobao wrote:If you've waited 2+ hours and restarting your phone does not work, there's a chance the port might have failed.
Moderater_Team can help you with submitting another porting request:
You can try to see if the people who you are calling/texting can note what number they're seeing from you, or if their calls to you are still going to your old provider voicemail.
Whenever possible, customers should be using SIMon to submit tickets. Using the method that you have provided will result in the customer receiving slower service.
When it comes to the number that shows on the call display when a call is made, this would be the ported number. Public Mobile assigns the requested phone number to the Public Mobile account before porting has even completed.
02-23-2021 09:21 PM
Thanks
02-23-2021 09:18 PM - edited 02-23-2021 09:29 PM
EDIT: As computergeek541 has noted, try the SIMon chat bot before resorting to Moderator_Team.
02-23-2021 09:18 PM
@Nazmul you need the old Fido SIM card in your phone to confirm the porting of your number from Fido.
Once you confirmed then install the PM SIM and reboot the phone.
Maybe contact the PM mediator to help with the porting.
02-23-2021 09:15 PM
@Nazmul wrote:@Anonymous : I didn't get any conformation from Fido. I restarted my phone.
Thanks
Carriers are supposed to send you a confirmation text when you request a transfer at a new carrier.
02-23-2021 09:13 PM
Thanks
02-23-2021 09:13 PM - edited 02-23-2021 09:14 PM
@Nazmul wrote:Hello, I have transferred from Fido to Public mob yesterday. Now I can only call others, but cannot get any call. How can I fix it. Thank you
Number porting has failed. You'll need to ask moderators to fix this. Open a ticket by going to: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Keep using your Fido SIM card as your phone calls are likely still going there.
02-23-2021 09:11 PM
@Nazmul : Did you leave your Fido SIM in to wait for the transfer confirmation? Have you restarted the phone after that with the new SIM in?
