Reply
Highlighted
Not activated
8hrs after activation from Koodo to Public moblie. Still no sign of network. Not even activation message sent. How long should i wait??
Accepted Solutions
Highlighted
Re: Not activated
I assume you have activated via activate.publicmobile.ca? If so, and I assumed you have reset your device etc only contact the moderators would help you via this link https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
However expect they will get back to you within 48+ hours.. as they don't work 24/7. Do note you are actually downgrading in terms of service from Koodo to Public Mobile, longer customer service response will be one of the things you will need to get used to.
All Replies
Highlighted
Re: Not activated
Highlighted
Re: Not activated
OMG😭😭😭🙄 WHAT HAVE IBGOTTEN MYSELF TO
Highlighted
Re: Not activated
Activation is supposed to be immediate, although number porting usually takes a short amount of time. I suspect that service might not have been properly provisioned by the activation system.
Highlighted
Re: Not activated
Yeah, it's time to email a moderator. Put in your old sim. If your port hasn't completed and your account is still active (which is has to be to port), your phone should still work with your last carrier.
Highlighted
Re: Not activated
Was your Koodo account pre-paid? Apparently Koodo pre-paid shares a database with Public Mobile so if you used the same email address for both carriers it can cause issues.
Is your Public Mobile self serve account functioning?
Highlighted
Re: Not activated
Same email i used with  PM Before moving to Koodo because  i started with public mobile. N now i changed back to Public mobile again.
Highlighted
Re: Not activated
@elixlolor   there's the problem,  you can't use the same email on public mobile!   You'll have to use a different one, or if it's a Gmail address you can always add a + and put new or something else at the end of your email name and that will work too
Highlighted
Re: Not activated
The Koodo rep that changed it never mentioned anything like that to me. I did it at d Koodo office in Brampton. She did the registration herself. Same place i got the public mobile changed to Koodo the first time. Changing from PM to Koodo did not stress me like this so why is moving from Koodo to public moblie now so problematic. Besides, if PM is not useable and if they cannot manage it well then it should be swipt out of Canada moblie network. 🙄 cos it does not make sense keeping someone without a network for more than 24hrs talkmore of 48hrs. We are not in the zoo this is Canada n they should act accordinly.
Highlighted
Re: Not activated
@elixlolor   was your credit card charged?
