Reply
Rick6
No mms Access
I have a sonim xp 7700 and no access to mms.  I should have that as part of my plan.  I've tried several ideas that have been posted with no success.
z10user4
Re: No mms Access
If you have data in your plan can you open websites?
It looks like that phone will barely do LTE here. If you can set it to 3G only might help.
Otherwise find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
will13am
Re: No mms Access
@Rick6, are you able to check and edit the APN settings on the phone?  It's usually that which affects MMS.
Rick6
Re: No mms Access
P.s.  I talked to sonim tech and they said the Sim card should have all the info for network access.  Should I try a new sim sim ?
z10user4
Re: No mms Access
I take back my comment about LTE. The manufacturer site suggests otherwise. It should work. So that leaves APN.
GinYVR
Re: No mms Access
@Rick6The MMSC and MMS APN settings have to match Public's for MMS to work, so it is best to verify those 3 entries, especially if your data work and MMS doesnt.
Rick6
Re: No mms Access
Your settings seem to be working.  Thanks for help.
