No internet connection when data is ON
Wanjimike
I bought a phone, (UMDIGI A9) unlocked, on amazon two days ago and subscribed to the 35 dollar plan. https://www.umidigi.com/page-umidigi_a9_overview.html.
I bought my simcard and plan at Walmart
However, I am unable to browse the net outside any wifi range. In other words I am unable to browse using my data. I still have alot of data on my phone.
I can receive and send messages.
I have ran through the hoops on this page: https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone,
This includes inputing the names CORRECTLY, no caps, no spaces, good spelling etc etc.
But so far nothing has resolved the issue, even after re-booting the phone.
Any help would be appreciated.
thanks
Mike
37 REPLIES 37
[Duplicated post due to post consolidation]
@Wanjimike  UMDIGI is a bit tricky to setup.  Its an APN settings that needs to tweak
check this link for how to get to the APN setting on UMIDIGI
Solved: Re: UMIDIGI Phones Supported - Community (publicmobile.ca)
These are the PM APN Settings:
APN settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,supl,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: Not set
MVNO value: Not set
Triguy
Double check your APN settings.  Did you turn in data ?  You might need to do a factory reset.
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Pixel-4a-set-up-APN-necessary/m-p/617...
APN settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
MVNO type: Not set
MVNO value: Not set
Wanjimike
Hello, I can only browse webpages when on wifi,
when i move out of wifi range, i cannot browse even when data is ON.
I have ran through all the hoops here: https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone and nothing seems to be working
my phone is UMDIGI A9. Any help would be appreciated
My data plan is 2 days old, so i still have lots of data on my phone,
i can receive messages and make calls.
thanks
Mike
@Wanjimike   what is the issue again?  you can only load webpages or use app when on Wifi and unable to use Mobile Data?
What brand and model of phones do you have?
Give us more specific details, like can you at least make calls or receive calls? just Mobile data is the issue?
@Wanjimike...to get the most help, best to start a new thread.
Wanjimike
I am having this same problem, I have ran through all the steps listed, but the phone isnt working. I am reconsidering moving away from public, really frustrated, online support just send links, upon links upon links to click on. No one seems to know what the solution is.
