01-13-2021 10:14 PM - edited 01-05-2022 04:51 PM
I recently transferred in from another carrier and I am able to receive and send calls and texts to another device. But for 2FA authentication like WeChat or Banking apps sending texts or voice messages/calls to confirm my identity, my device is not able to receive theses communications. I have the following plan and addons:
Any idea how I can receive these messages?
01-14-2021 01:58 AM
I think in this case you need to contact a moderator, because there is a block on short text codes. A specialist should be able to remove this.
01-13-2021 10:31 PM
Thanks for the quick response. I tried with another device on Fido and noticed that it isn't able to send messages or dial the ported number. Is this a porting issue or should I just wait a few days
01-13-2021 10:20 PM
@blurpleberry hi I have read from other posts for 2FA authentication like WeChat or Banking apps there is usually a 24 to 48 hour wait after porting from another cell provider before they work
01-13-2021 10:20 PM
@blurpleberry wrote:I recently transferred in from another carrier and I am able to receive and send calls and texts to another device. But for 2FA authentication like WeChat or Banking apps sending texts or voice messages/calls to confirm my identity, my device is not able to receive theses communications. I have the following plan and addons:
- - Unlimited Canada-wide Talk
- - Unlimited International Text
- - 500min INTL Long Distance incl CA & US
There have been some reports that after a complete number ported, these types of messages don't work for the first 48 hours. I would try again after waiting a few days.
