No data plan-will I be able to use Picture Messaging?
BRCD
If I just get the Talk and Text plan(NO DATA) will I be able to send and receive pictures through text messaging. Currently with Koodo I have to turn on my data for a few seconds everytime I want to receive or send a picture through texting. Pain as I constantly having to call and complain to get charges reversed for data useage.
7 REPLIES 7
David01
The nice thing about prepaid is that turning data on when you don’t have any included, won’t incur extra charges, so it will only use the data necessary to complete the sending of your MMS. If you have picture messaging included in your plan, the data use for it is free of charge 😀 Unlike post-paid plans which will incur unwanted data usage the second anything comes in.
BRCD
Got it, Thanks
closng
Hi @BRCD,
To add to the above, although you do not have a data plan, you will still need your data to be turned on, on your phone, for MMS to work.
kav2001c
@BRCD what you wrote right here; LEAVE DATA ON even if just a talk & text plan
Disabling it can cause all kinds of weirdness in MMS not sending
This is an Android (and to lesser extent Apple) issue, not a carrier issue
Public Mobile is a prepay system so you will never incur extra charges
BRCD
Good, yes understood in Canada. Thanks for your help.
Rabbi
@BRCD its will only work when you in canada but when you will be is the usa with rooming addon you will have to buy also data that mms will work there
Rabbi
yes i have talk & text and mms also work
