I picked mine up at wal mart
I would just order from the website.
If i order a new sim card, can I keep the phone number attached to my old PM sim card?
Yes.there is an option in selfserve which allows you to change sim card number
I believe you assign the number to the SIM, so yes you should be able to just assign your #, but why is it you need a new SIM
I want to buy a new phone but my old PM sim card is too big for most.
@Elsa_Zeta, you have a few choiceS. You can cut your sim card to fit ( there is lots of information about this on the net). You can get someone to cut it for you. You can order a sim on line from Public Mobile. You can get a replacement sim from a retailer like WOW mobile or Walmart (note that some Walmart locations won't sell you a sim without activating it on site.
Assigning your number to a new sim is a very simple process, I’ve done it many times myself. Please let us know how it goes.
@Elsa_Zeta a little off topic but pm has been selling triple punch Sims for a long time. Are you on a legacy plan or an in market plan? The base inmarket plans tend to be cheaper than the legasy plans after the recent legasy plan increases.
visit to near walmart store you will get it that way faster also
