Reply
Retraité / Retired
Need a replacement SIM card?
Getting a replacement SIM card is easy - just order one for $10 on our website!
Keep in mind that:
  • SIM cards are shipped within Canada only and will arrive within 3-4 business days via Canada Xpressport.
  • 10 SIM cards per order
  • Our Triple Punch SIM cards have all 3 sizes (Standard, Micro and Nano) in one card! All you need to do is “punch-out” the size you need for your phone.
  • We’re also pleased to announce that our SIM cards will now be available to purchase at over 350 Walmart locations across Canada. More info here
Last updated on 26/07/2017
pav
Re: Need a replacement SIM card?
Hmm, I tried to order a sim card using the online tool but for some reason it fails to recognize existing PM subscribers with active accounts.
At first I thought it was a browser issue, but I get the same results with Safari, Firefox, and Chrome.
Legend
Hello,
Did you first create a Shopify account after clicking Order Now, which is immediately under Order a SIM Card?
I tested the above about 2 weeks ago. From start to finish, I encountered no problems. Plus, I received my card in 3 business days.
You experienced a glitch.
The MAIN objective of PM is to make the servers much more robust, so that all the problems recently encountered will be relegated to the past, and the site will be truly self-serve without problems.
I hope that this has served to allay some of your concerns.
pav
@Martin
I simply followed the link on the PM site and added a SIM card. I entered my active PM account credentials at checkout and the system kept stating these were invalid (credentials work fine when I  login to check my PM account, btw).
Your response suggests PM credentials at checkout are actually a seperate Shopify account and not an active PM account or did I misunderstand?
Legend
Hi,
The credentials at checkout can be different than those in one's account. How do I know? I used a false name. :-)
I inferred from your response that you did not create a Shopify account. If my inference is correct, please create that account, and then order your SIM card.
Thank you.
pav
Ha Ha. OK. Well it seems I might have discovered a glitch with regard to existing user accounts.
The log-in for ordering is  "store.publicmobile.ca" which is different from the standard PM account which uses "selfserve.publicmobile.ca"
I'll leave it to PM reps to verify.
Legend
Hello pav,
I have a question for you. To which credentials were you *specifically* referring? We might have different ones in mind, and I want to ensure that my reply of 11:14 pm EDT was correct.
Thanks.
pav
@Martin
I was referring to the PM login credentials (for existing account holders).
What happens to my current plan when I replace my SIM card with a new one?
I am halfway into a 90 day plan and don't want to lose the remainder of the plan.
Hey @Cookin,
Nothing changes as far as your current plan is concerned.
You simply need to sign into your account, register the new sim card by going to "Chnage sim" and enter the new sim card's serial number.  Once registered, insert the new sim in your phone and carry on using your plan uninterrupted.
