03-13-2020 04:35 PM - edited 01-05-2022 09:55 AM
Hi. Today I found I cannot access my mobile data anymore.
My data is not working anymore.
I cannot turn on MOBILE DATA (I cannot select it to enable it). Mobile data is gray out , I cannot enable it. I tried to disabled my Bluetooth, same.
Asus Zenfone 5Q
Settings , Network & Internet, Mobile Data(enable)
Disable your wifi
Access point names, Public Mobile then click on + to add
the APN setting.
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,supl
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
Try to send whatapp message to see it is working or not,
if working
1. Make sure you disable your DATA PLAN from public mobile
enable you data now.
03-13-2020 07:00 PM
@chinee899 Can you make calls? Send Texts? Connect to the PM network? If not, then check your SIM. Maybe call your number from another phone to make sure your number wasn't ported out.
03-13-2020 06:32 PM
@chinee899, hello fellow Asus owner! I have the Asus Zenfone 3 Max, got my dad the Asus Asus Zenfone 4 and my mom, the 6. Great phones. On that note,
I
03-13-2020 05:20 PM
@chinee899 If you cannot enable Cellular Data on the phone nothing PM can do will help.
If is this a dual SIM phone make sure you looking for the settings of the correct SIM slot.
03-13-2020 04:50 PM - edited 03-13-2020 05:07 PM
@chinee899 try changing your settings as follows:
APN type: default,mms,agps,supl,fota,hipri,dun
MVNO type: GID
MVNO value: 4D4F
Have you tried your drop down menu to enable mobile data? And please check your plan to see if you have used up all your data. If you can enable data, try sending/ receiving an mms message. If this works, your APN settings are correct. Thanks
