01-13-2020 01:47 PM - edited 01-05-2022 09:00 AM
Hey everyone! I am just wondering why I seem to not have any access to mobile data, despite having it setup properly on my phone (LG Q STYLO +) & having a plan that is supposed to include data...
Yet, i am only able to connect using wifi.. anyone else have this problem??
01-13-2020 07:45 PM
Check it online and see how many data did u used as someone already mentioned. There is option on phone about the data usage so you can set it up example 80% so once you reach 80% you will get a notification how much data is left for the month.
Thnaks!
01-13-2020 02:52 PM - edited 01-13-2020 02:59 PM
@ho0terella wrote:Hey everyone! I am just wondering why I seem to not have any access to mobile data, despite having it setup properly on my phone (LG Q STYLO +) & having a plan that is supposed to include data...
@ho0terellaPlease check the following: (test data after each step)
01-13-2020 02:25 PM
@me003 wrote:LG mobiles are known for making issues even with correct APN settings.
Best remedy :
1)Back up all your data
2)Go to settings and do a factory reset followed by network reset
3)Go to APN settings and enter all details again(fresh entry)
I hope it will work. I am a fellow LG user.
Do the network reset first. If network reset does not fix your data issue, do a factory reset as about. If factory reset does not work, add APN manually as previous post.
01-13-2020 02:08 PM
Best remedy :
01-13-2020 02:06 PM
No, by set up, is mobile data enabled? Etc. Did you receive the 75 and 95% PM text notification warnings from 611 about your data useage? If you did you are probably out of data as mentioned above . You can either buy the 200mb or 1 gigabyte data add-on in my account(this is expensive). Or wait for next month.
01-13-2020 01:58 PM
It is a common issue with APN settings. .Check the APN settings in your phone.
These are the Public Mobile APN settings you need:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F or 4D
Don't forget to save these settings and then select this APN as the active one.
If you need to know where to find the settings:
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
01-13-2020 01:51 PM - edited 01-13-2020 02:12 PM
When you log into your account - is an amount for data showing ? If not then your data has been used up. If you have data remaining then try rebooting your phone.
01-13-2020 01:50 PM - edited 01-13-2020 01:52 PM
Check your self-serve account. Do you see any data remaining in your plan under "My Data and add-ons"?
If the line is no longer visible, it means you have used up all your data. To add more data, you can buy an add-on, change your plan or wait for your next renewal.
