04-01-2019 09:23 AM - edited 01-05-2022 04:06 AM
Hello, I am in the public mobile, but I filled in the wrong MEID, but the phone can not set APN, can not access the Internet
04-09-2019 03:41 PM
@yanghao941le any updates?
04-01-2019 07:37 PM
@Luddite wrote:@yanghao941le What is the make/model of your phone?
@Luddite this is a very important question. I'm guessing this may be an overseas phone without compatible UMTS frequencies.
@yanghao941le I noticed too that you have selcted the Telus APN (sp.telus.com) rather than the Public Mobile one (sp.mb.com). You may need to enter manually, but please start with @Luddite's question so we can try to confirm compatibility first.
04-01-2019 05:10 PM
04-01-2019 05:07 PM - edited 04-01-2019 05:09 PM
@yanghao941le wrote:Hello, I am in the public mobile, but I filled in the wrong MEID, but the phone can not set APN, can not access the Internet
Does your phone actually have a MEID? MEID was generally introduced to replace ESN, particularly for some of the "newer" CDMA devices. I am thinking that you mean IMEI.
As for entering the wrong IMEI, the only time that you need to enter that is if you have chosen to the that for number porting, although other pieces of infromation can be used for a phone number transfer.
If you're speaking just of the Public Mobile compatibility checker, it doesn't actually matter what you type into that, nor do you even have to use that tool if you know that your device is compatible with Public Mobile.
04-01-2019 05:01 PM
04-01-2019 09:54 AM
@Alex888 wrote:
@will13amHe said he entered the number in wrong, i told him to contact the moderators to change the number on his account, not the number on his phone.
I am somewhat confused by the OP myself. It seems like the issue is with getting mobile data to work. It is obvious the APN settings shown are not correct for this service. As for entering IMEI, it has a role in number porting. I did not see any reference to number porting being a problem. Apart from that, do you know of any other place in the account that requires phone IMEI?
04-01-2019 09:44 AM - edited 04-01-2019 09:49 AM
I am not sure your internet access problem is related at all to MEID. I do not recall having to enter such information upon account activation. Perhaps there is another issue.
Have you tried restarting your phone?
Or your phone may not be compatible with Telus/Public Mobile network?
04-01-2019 09:38 AM
04-01-2019 09:34 AM
@Alex888 wrote:@yanghao941le To change your IMEI number you will have to contact a moderator, you can send them a private message here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
What type of phone do you have?
The moderator team cannot change a customer's phone IMEI. I am not sure whether it is legal to do something like this. Each phone is provided with a unique IMEI by the manufacturer. Changing it is similar to changing the serial number on a car.
04-01-2019 09:32 AM
@yanghao941le, when you say you entered the wrong MEID, is that in the phone compatibility checker? What model of phone are you using and what android edition is installed on the phone. Android 8 had issues with lost ability to enter new APNs.
04-01-2019 09:27 AM
