05-10-2016 05:50 PM - edited 01-04-2022 12:53 PM
Hi there,
I am trying to activate / register my new PM sim and I am stuck at step number 2, where I must choose whether to port or to get a new number. I want a new number but this does not seem to be possible. There is no area code number to choose from, all I get is a blank (dysfunctional) dropdown. I am new to PM, but from what I understand they do operate fully in Quebec. And since I live right next to the Montreal downtown area, it must not be a problem with my location I assume and hope.. I mean not having any numbers available for some more remote areas for ex (*since the numbers are derived dynamically from the user's address in step one).
I tried both with Firefox and Chrome, same problem. Screenshot->
PS: *I checked the js console in ff on my second time around and there were no errors. Well, there was the https mixed content blocked thingy, but I reloaded the page without the block and it was the same, so it doesn't count I guess.
Thanks
11-30-2016 11:46 PM
I'm having the same problem...
stuck at the new number page - field for local area number is empty
It really is hard to believe you have this so basic programming bug for so long.
Unbelievable !
How to solve it ?
Please, need help urgent !
Thanks
Kiran
11-11-2016 10:05 AM
Hey, @e-leven a friend of mine is having the same problem, how did you fix it?
05-12-2016 03:34 PM
@e-leven, don't worry about it! When you send me a message refresh your the community page from time to time, because we do not send notifications for private messages.
We are here to help 🙂
Thanks,
Shazia
05-12-2016 03:29 PM
Hi Shazia I'm really sorry I did not receive a notification for and did not see it.
I will send you the info, thank you very much.
05-12-2016 03:21 PM
Hello @e-leven,
I sent you a detailed reply yesterday at 1:01 pm can you please open my message and reply back ?
Thanks 🙂
Shazia
05-12-2016 03:19 PM
Hello Shazia,
I sent you a PM with the info you requested more than 24hrs ago and I haven't received a reply. Could you please give me an estimation as to how long it will take to get my sim card registered?
Thank you
05-11-2016 09:29 AM
Hello @e-leven,
I'm really sorry to see that you were having issues activating your SIM card.
I will be glad to assist you with this process, would you kindly send me your Public Mobile SIM card number as well as the email address used for activation?
Thanks,
Shazia
05-10-2016 07:33 PM
05-10-2016 06:45 PM - edited 05-10-2016 06:51 PM
This doesn't seem to be the problem. I wrote the previous post without really considering that the cache / cookie was the culprit, because :
a-) I noticed that when you first get to step 2 the option for getting a new number is preselected by default, yet there is no dropdown visible at this point (this seems wrong and it's likely that should not happen). To get the dropdown to appear (albeit empty), you need to toggle between the options. So select option to port brings port over form and then select new number brings the empty dropdown.
b-) The other reason I thought this, was because my chrome browser is used for web dev and testing and so the cache / cookies are regularly cleared (+ I don't think I ever visited the PM site before with this browser, let alone try to register or anything like that).
1- So in a nutshell I tried with all cookies / cache cleared and got the same result.
2- I then tried this registration/activation from my mobile (android), same thing exaclty.
3- I then recleared all cookie cache and opened an in cognito tab(!) to try. Still same.
The only good thing that has come out of this so far is that I finally know my postal code by heart 😐
Thanks
05-10-2016 05:59 PM
Sounds good, @e-leven. Please let us know, one way or another.
05-10-2016 05:58 PM
Ok thanks I'll give it a go.
05-10-2016 05:55 PM
@e-leven In the past, PM community staff has insisted that this issue is caused due to something related to cookies/cache. Can you please clear your cache and cookies and confirm if the issue persists?
