I pad
coeneb20
Am I able to connect a I pad as opposed to a I phone to one of the plans.
mh1983
Here's a link with some visuals that may help: https://support.apple.com/en-us/HT201471
All iPads are available as a wifi only or a wifi and cellular model. It is always at least $100 more for the cellular model so if you didn't specifically purchase one with cellular built in, it is unlikely to have it.
AE_Collector
@coeneb20 wrote:
Do you know if a i pad 8 would have that
You can quickly tell if your iPad is capable of mobile connectivity by looking for the SIM card slot on the side. If you see one then it's a Wi-Fi + cellular model. If not, then it's Wi-Fi-only
coeneb20
popping
Yes, if you have a iPad with WiFi + Cellular support - Not the iPad with only WiFi support.
