12-27-2018 04:07 PM - edited 01-05-2022 02:53 AM
I am having this problem on my phone where I can't call on my phone. Every time I make a call, the same message will pop up over and over again; "Mobile network not available." And the message sometimes will vary and it will pop up instead "Enable Wi-Fi calling to make a call." This is starting to become a really big problem for me, and if this keeps up, I might have to switch to another phone operator. If you are having the same problem or know a solution to my problem, please comment down below. Thank you for your time reading this
01-03-2019 02:49 PM
@patrickmissick wrote:I payed for my plan this month. Everything should be working fine but it's not.
@patrickmissick try these workarounds to see if they help, they usually do: https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/SOLUTION-My-plan-has-enough-f...
01-02-2019 10:32 PM
12-27-2018 07:37 PM
Try putting 1$ on your account. It might help it reset, that's what I did and it worked
12-27-2018 07:35 PM
Did you miss the rest? Like the part I said where I have paid the plan upto date ? And it's still not working ?
12-27-2018 06:53 PM - edited 12-27-2018 06:55 PM
Check your phones network settings..also..is this a new activation or have you had service before?
12-27-2018 06:30 PM
I keep trying to refresh my phone, restarting over and over, but the same message pops up "Mobile network not available" I payed for my plan and everything but I can't make calls or text. I don't know if this is a signal issue or a phone issue or a retailer issue...
12-27-2018 05:28 PM
Two alarms go off...missed payment..and changed plan...more info needed to decifer the problem...
12-27-2018 04:46 PM
I'm having the exact same problem, I usually have money in my account for the renewal but this time I was a day late and wanted to change my plan and now after I paid for that plan I can't call or text or use data
12-27-2018 04:13 PM
@patrickmissick wrote:I am having this problem on my phone where I can't call on my phone. Every time I make a call, the same message will pop up over and over again; "Mobile network not available." And the message sometimes will vary and it will pop up instead "Enable Wi-Fi calling to make a call." This is starting to become a really big problem for me, and if this keeps up, I might have to switch to another phone operator. If you are having the same problem or know a solution to my problem, please comment down below. Thank you for your time reading this
Is this a recent problem or has always been going on. Have you had yoru PM service up and running normaly? What is the make and model of your phone.
