Reply
Highlighted
HotSpot Not working
I joined Public Mobile on the weekend and despite quite a bit of research, I have not found a way to get hotspots to work (even though the second device says it is connected).
I found an older thread where individuals were talking about changing the APN settings (particularily with a focus on adding "dunn"), however, my phone does not allow me to add new APNs or change existing ones.
Any other ideas for next steps? This was a fairly important feature for me, so I am hoping to figure it out.
On Android 9 btw
Highlighted
Re: HotSpot Not working
On Android 9 btw
Just to be clear. You have set up YOUR Android to be the HOTSPOT? If yes, did you assign a password for it?
Highlighted
@RobertM24  inserting a freedom mobile SIM allows you to change your apn settings when other Sims, including PM Sims don't.
Highlighted
Correct. The device with the PM sim card is Android 9.
I did set up a password when I created the hotspot.
Highlighted
Does this work universally?
I definitely do appreciate the input, but I hoping to be reasonably sure before I spend money on the solution.
Highlighted
@RobertM24 I can't say for sure that it works universally. You could ask a friend to borrow one and insert it into your phone, or go to a kiosk, explain your situation and ask nicely for an old one to insert in your phone.
Highlighted
Another suggesting is turn off Data Saver on your phone.
On Android 9 btw
There is a small app can add new APN on Android phone. I used it for my Asus Zonfone 4 Max to add new APN. If you need it send message to me.
Another suggesting is turn off data saver on your phone.
Highlighted
On Android 9 btw
What is your phone? I've just checked my SIM with Redmi Note 8 and Galaxy J1. They both create and connect to hotspots easily and internet is working for a connected device.
Highlighted
@hycm53 wrote: There is a small app can add new APN on Android phone. I used it for my Asus Zonfone 4 Max to add new APN. If you need it send message to me.
Is the app the one from RFD? "MyNewAPN"? I installed this, removed the sim card and restarted and it still doesn't work. Maybe it's specific to my phone?
Unfortunately, data saver is off already.
If the app is different, I'd be happy to try it as well
Highlighted
It's a Umidigi A5 Pro.
