12-05-2019 11:47 AM - edited 01-05-2022 08:20 AM
What if I exceed the data limit. Will I get throttled low speed internet ? For normal browsing and checking the emails etc.
12-06-2019 04:54 PM - edited 12-06-2019 04:56 PM
@popping wrote:
@Korth wrote:I am curious. Please tell us which Add-on gets used first the next time you start using a mixed pool of Data Add-ons, lol.
I expect the first bonus 1GB data first. I will know sometime tomorrow. One of my plan only has 0.5MB left out of 250MB plan data.
Update: Instead of using the first free 1GB data add-on, PM server uses the new holiday giveaway from couple days ago even I started using the first bonus data already.
12-06-2019 01:09 PM - edited 12-06-2019 11:50 PM
12-06-2019 01:07 PM
PM does not provide unlimited data after you use all your data. The data would be stopped and you can top it up with an Add-on to keep using it at 3G speeds.
12-06-2019 07:24 AM
You cannot go over your limit, it just stops once you consume what you have. PM don't offer unlimited at throttle speed...
12-06-2019 02:01 AM - edited 12-06-2019 02:01 AM
12-06-2019 01:54 AM
12-06-2019 01:47 AM
To add to what the others have already said, the one time add ons are good option for "every now and then" going over your plan limit as what you don't use from the add on is carried to the next time you go over. However if you are frequently going over you may want to look at plans with higher data.
12-05-2019 12:16 PM
Data will stop after using all your plan data quota. But you get the free 1GB data to tie you over to your next cycle. BTW, this is the second free 1GB data in 3 months. I still have 300MB left from the first free 1GB data.
12-05-2019 11:56 AM
@Ruosbrown wrote:What if I exceed the data limit. Will I get throttled low speed internet ? For normal browsing and checking the emails etc.
No your data will just stop, there is no unlimited data here and it is all prepaid so if you haven't paid for it you won't get it. Which also means no overage charges.
Have you heard that PM is giving 1GB of free data nd 400 international minutes to every customer? You can get these by going to your selfserve and selecting purcahse add-ons and look for the GIFT add-ons!!
