10-06-2021 11:01 PM - edited 01-06-2022 03:43 AM
I just activate my new PM sim card and I notice I can write my full first name. I am from south america and my first name is made of two names. The input box has a limit of 11 character, my name fails by 1. I don't have issue with my last name (also made of two words) as the input box has a limit of 18 charaters.
This is the first time I have issues signing up to a service where I can't write my full name.
I am worried that I will have problem if I try to setup autopay.
What I can do ?
Thanks.
10-07-2021 02:48 PM
@hairbag1 wrote:
Your Autopay info is the exact name on the credit card / debit card though.
Assuming credit card name field has no length restriction?
10-07-2021 02:40 PM
in your credit card what is your name entered they same,
just make sure your credit card number and your address match the same,
sometime your typing but is a one word or letter or number is a wrong or is missing just make sure for it.
10-07-2021 06:55 AM - edited 10-07-2021 07:01 AM
Whatever name you use, just be sure to remember it in case you need to contact CS later for some issue involving your account.
It's always a good idea to take a screenshot of the Overview and Profile pages of your account and save it somewhere so you can give the exact information when asked.
10-07-2021 01:25 AM
you can try taking out the space between your two first names.
Autopay will still match what you put as your name on the card, doesnt matter it was same as your PM registered name or not.
Just an idea.
10-06-2021 11:41 PM
You can shorten your first (two) name by using one or the other of your first name.
You can use your full name as on your credit card.
10-06-2021 11:09 PM - edited 10-06-2021 11:10 PM
@zarge wrote:I just activate my new PM sim card and I notice I can write my full first name. I am from south america and my first name is made of two names. The input box has a limit of 11 character, my name fails by 1. I don't have issue with my last name (also made of two words) as the input box has a limit of 18 charaters.
What I can do ?
Thanks.
@zarge no worry about the name field on My Account. The credit card info require you to enter the name again, it does not take it from the name on the My Account
10-06-2021 11:03 PM - edited 10-06-2021 11:06 PM
What I can do ?
Thanks.
You can sign up with any name actually....just shorten your name by a vowel or whatever works. Your Autopay info is the exact name on the credit card / debit card though.
