Data turned on - Not receiving Data
Brentimir
Hi there,
Just joined Public Mobile. I have data in my plan - my data is turned "on", but I am not actually connected to any data (for example, YouTube does not load). I have a Sony Xperia XA.
Everything else is functioning fine - calls, text, wifi, etc. Just no data.
Help?
9 REPLIES 9
@arianapham wrote:
I resemble your case and don't know how to solve it
 @arianapham
What make/model/submodel phone is it?
Has data ever worked here?
Have you checked to make sure you see data in your overview data & add-ons area?
Find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
arianapham
I resemble your case and don't know how to solve it link
phamyen
MARVEL Strike Force apk - download apk is a turn-based role-playing game, where players have the lives of any of their favorite Marvel superheroes. Recruiting Marvel classics such as Spider-Man, Thor, Captain America or Doctor Strange; or join with evil forces like Crossbones, Loki, Venom or Kingpin (among others).
@Brentimir wrote:
Hi there,
I inputted the exact APN setting values and names... but nothing happens. I ensured that the new APN is being used (it is my only APN available). I then turn my data on, try sending a picture message... but nothing happens. I am still not connected to any data network. I also tried downloading the app suggested, but it didn't really offer anything new compared to the steps alredy provided.
So, what now?
Did you go here and find your phone?
Edit: nvm. your phone is there
Re: Data turned on - Not receiving Data
@Brentimir You can Google MyNewAPN_test.apk. This is working for Asus Zonfone 4 Max that I have and I'm not sure it's working for you phone, but anyway you can try it.
You can pm me I will sent the app to you if you can't find it. But you will take your own risk, I shall not be responsibilities for any damage your phone.
Brentimir
Hi there,
So, what now?
@Brentimir If still doesn't work, you may try install this app, but I'm not sure it will work.
https://apk-dl.com/apn-settings/net.thenatureweb.apnsettings
hycm53
jotsang
@Brentimir wrote:
Hi there,
Help?
Double check your APN settings as per instructions here:
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
