Reply
Highlighted
Data overages
PM states on the home page that they don't charge for data overages. Is that a fact or an error? Haven't seen much info about it. Would be nice if it is factual.
Highlighted
Re: Data overages
It's a.fact. if you run out of your PREPAID data, data just stops.
Highlighted
Re: Data overages
PM is a prepaid service. When your data allotment runs out, then you will not have data. PM will not provide data and charge you  for it.
Highlighted
Re: Data overages
@PAULRANG18hi you are absolutely right there are no overages when you run out it just stops that is the beauty of PM you can always buy an add on after you run out if you wish but you will have no surprise bills Smiley Happy
Highlighted
Re: Data overages
We're all so used to getting hosed by the other cell providers that it actually seems odd to find a provider that doesn't have overages. Once you've been with Public Mobile for awhile, you'll look back and think "why did I stay with the other guy so long ?"
Welcome to $aving a few buck$.
Highlighted
Re: Data overages
Yes.  PM prepaid does not working like other prepaid service in Canada.  After you consured all your attoted data, your data will stop working because PM does not have pay-per-use.  Your available fund in your account will be safe.
Other prepaid service in Canada, for example Chatr, has pay-per-use.  As long as you have fund in your Chatr account, Chatr will use your fund in your account to pay for overage.
Highlighted
Re: Data overages
You receive SMS notifications when you reach 75% and 95% thresholds on your Plan's Data allocation.
At 100% you get no more Data for the remainder of your billing cycle (unless you buy a Data Add-on or buy a Plan). Your device will still connect to Data on the network but it can't be used for anything except MMS attachments and redirects to PM's webpage (explaining why you have no Data and allowing you to login Self-Serve to buy more).
(My understanding is that these system notifications can be wrong or meaningless if you already have any Add-on Data available when reaching the thresholds. Not sure exactly what happens in that scenario, I've never tested it and different people have reported different things.)
There's usually (small) discrepancies between device-side Data usage measuring apps and network-side Data usage measurements. Only the network-side numbers matter, the usage on your billing is what you're billed for, the device-side numbers are functionally only rough estimates.
Highlighted
Re: Data overages
After running out of data, the network does intercept your webpage loading request and attempts to load a Public Mobile webpage showing an error message. However, that page will not load because you are out of data. As such, you also will not be able to get into Self Serve using your mobile data connection.
To be able to see the error message website about possible reasons for data not working, the user would need to connect to the internet through Wi-Fi and tell the web browser to reload/refresh the page.
Highlighted
Re: Data overages
I've also read reports of MMS attachments not working consistently or at all after Data is all used up.
But I specifically tested the limits my first month on a 30-day Plan (had lots left and only a couple days before renewal), I had Data to burn and I wanted to know what to expect (warnings, etc) on future billing cycles.
My browser (successfully) went to the PM redirect page with Data ON and WiFi OFF (and my home WiFi unplugged). So I know that works, though I don't know if it's the same everywhere for everyone.
MMS attachments (well, technically a single attachment which travelled around a lot) still worked for me, Province-wide, Canada-wide, with several people, both ways.
My next bill cycle is in 4-5 days. And I still have almost all of my Data left unused (again). I was planning on running a bunch of Speedtests in all the usual places I use my phone. But I can test the above things again. And I can test other things, if anyone has questions or ideas.
Highlighted
GR
Re: Data overages
My kids are all on the 25$ plan with 1gb of data and they usually use a ll the data within a week or two and for the rest of the month they don't have any problems sending or receiving mms  messages!
