Data on iPhone not working
ellenyw
Hello!
I've been with Public Mobile for a while and my data has always worked fine. However, I got a iPhone SE and plan that just started a few days ago with PM. I have changed the settings on the APN to sp.mb.com (I can only see APN settings for personal hotspot, not the other options).
When I turn on data, the LTE/3G symbol will show at the top but I will get a message saying "could not activate cellular data network" 😞 I do have a data plan so I don't understand the issue.
Please if anyone knows how to fix this, that would be amazing!
13 REPLIES 13
erinashleigh
@ellenyw Thank you for sharing this solution! My data original worked when I set up my phone with Public Mobile but I never thoroughly tested it and my old apn profile must have overridden it.    As soon as I deleted the old profile my data worked again!
MG2019
Did you ever get your data to work?
GusM
Thanks, tried it and now data is working fine.
CalgaryBen
@cindyhoughton are you certain your plan includes data? Check in your self-serve portal, and ensure you have available data under the "My Data & Add-Ons" secton.
On your iPhone, make sure you're not using a configuration profile (often used in corporate environments, but it doesn't sound like your case... but just to make sure...): Settings --> Cellular --> Cellular Data Network --> Reset Settings. This will ensure the phone reverts to PM's settings.
Also, make sure you have the latest iOS (check in Settings --> General --> About). As of this writing, you should have iOS Version 12.0.1, and the Carrier profile should be Public Mobile 33.0. If either of these is not up-to-date, your best bet is to update them (Settings --> General --> Software Upate).
Help this helps!
cindyhoughton
i have a i phone 6 s plus i activated plan yesterday in the store i bought it in and the data plan does not work  help
cindyhoughton
do you know what the anp should read
ellenyw
Hi @andrewface,
Try going to iphone settings >> general >> profiles and device management
and see if there is any APN profile there?
Also under mobile data, do you see "mobile data options" or "mobile data network"?
I think some companies may lock that but you can also change the APN info there?
andrewface
I am experiencing this same issue but now with IOS11 there doesnt appear to be a profile option under general. I was on freedom so it makes sense that my phone may have had other APN settings. Is there another way to reset these?
Totalrookie
I wonder if I'm having a data problem. I cannot download apps from the Google Play Store.
I'm trying to download the Ontario Lottery ticket checking app.. I've checked settings & re-booted but nothing works.  Should I check the APN on the phone? Very confused & irritated by this.Smiley Sad
Michaelpierce
I moved to another network before a week. Then I have fetching problem on my iPhone cellular data (Mobile Data) not working. But I found a online guide about the cellular data not working and it worked for me. : https://www.howtoisolve.com/fix-iphone-cellular-data-not-working/
yyy_pmobile
I just activated an iPhone SE coming from Telus and didn't need any APN changes. I also only see Personal Hotspot under Settings->Cellular->Cellular Data Network, but I left it at isp.mb.com and did not hit "Reset Settings". Works fine so far (youtube, google news working fine with wifi turned off).
mimmo
Glad you solved it.  typically the two most common data issues are
  1. wrong APN setting
  2. data allotment used up
ellenyw
hm, I think I may have solved it!
There was another APN profile on my phone that was overpowering the normal settings I think. I'll just post here for anyone who has a similar issue:
Go to Settings --> General --> Profile
After deleting the old profile, data seems to be working!
