Hi all,
I've recently activated a new SIM card - calls and texts works but I cannot get data to work. I have tried several things, many listed on this website, but to no avail. I've tried installing different profiles too (Public Mobile, Telus) but this has not worked either. Could anyone offer any help?
Thanks,
Ben
Hi @bennn ,
EDIT:
@bennn wrote:Hi all,
Thanks,
Ben
Make sure that Data is enabled on the phone itself in Settings.
@bennn Check data and add ons in Self Serve and confirm your data allotment figures.
Hi @bennn ,
EDIT:
@bennn :Have you tried setting the APN again? Will look for link for you.
@bennn :Try this link for iPhone6:
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/APN-for-iPhone-6-Data-add-on/m-p/406016
Data does not work at all? You might have some apps turned off so when data is on they won't be used.
Thanks for your help! I followed your steps, I think updating the software on my phone did the trick. Thanks so much this has been giving me grief all day!
Good to know that update of IOS 14.4 was the issue. IOS 14.4.1 or 14.5 is coming soon.
