Reply
Highlighted
Compatibility with Xiaomi Mi8
Hello,
Does anyone know if Public Mobile is compatible with Xiaomi Mi8? I have looked through the compatibility list but only saw Xiaomi Mi6 and earlier models. Can someone confirm on why Mi8 may not work?
Thanks in advance.
Tags (3)
Accepted Solutions
Highlighted
Re: Compatibility with Xiaomi Mi8
@Jh831 wrote:
Hello,
Thanks in advance.
@Jh831  Yes it is. Smiley Happy
That phone supports the following bands: (Public Mobile uses:)
4G LTE
B1 (2100), B2 (1900), B3 (1800), B4 (1700/2100 AWS 1), B5 (850), B7 (2600), B8 (900), B12 (700), B17 (700), B20 (800), B34 (TDD 2100), B38 (TDD 2600), B39 (TDD 1900), B40 (TDD 2300), B41 (TDD 2500)
3G
B1 (2100), B2 (1900), B4 (1700/2100 AWS A-F), B5 (850), B8 (900), B34 (TD 2000), B39 (TD 1900+)
All Replies
Highlighted
Check frequencies on the model you you have
To make calls it will need umts 850 and 1900.
Here is @RobertQc answer to frequency question
Who was your previous provider?
Highlighted
Check the phone specs.
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
Please note that this information is indicative only. Your phone's compatibility with our 4G or 4G LTE networks is based on the radio frequencies of your phone. Public Mobile does not guarantee that your phone will work on our mobile network.
Highlighted
@Jh831 wrote:
Hello,
Thanks in advance.
Which Xiaomi Mi8 model do you have?
You need to find out the exact you have and use the following link to find out whether your phone will work with PM.
https://www.frequencycheck.com/carrier-compatibility/Lzarn/public-mobile-canada/devices?utf8=✓&q%5Bf...
Highlighted
@Jh831 wrote:
Hello,
Thanks in advance.
In general, it should be ok if you have their Global version.
Highlighted
@Jh831 wrote:
Hello,
Thanks in advance.
4G LTE
3G
