Reply
Checking Voicemail Messages from Another Device
Hi Everyone,
Does anyone know if there is a number to call (and login) to check our voicemail messages from another device? I am trying to understand how I can retrieve my voicemail messages without using my own device.
Thanks in advance!
Re: Checking Voicemail Messages from Another Device
@fchung wrote:
Hi Everyone,
Thanks in advance!
Call your own number from a land line, other cell phone etc. When the voice mail greeting plays press "star" / "*" and then follow the prompts to enter your voice mail PIN.
I believe the initial set-up has to be done from your own phone / SIM associated with the number, though.
@fchung wrote:
Hi Everyone,
Thanks in advance!
Yes.  You can call your PM phone number from another phone and supply your voicemail password and access your voicemail.
@fchung as noted, dialing your own number is probably easiest.  OR, you can dial your local voicemail access number from this list:  https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/access-voice-mail-out-of-home...
Tav
You would call yourself and then press * when the voicemail starts playing and then you should be prompted to enter your password.
Thank you
