11-21-2016 01:01 PM - edited 01-04-2022 01:16 PM
I tried to set up call forward on Android phone. Aftger inputting the forward phone number, the message says:
Call Setting Error
Unexpected response from network
How can I fix this problem?
Thanks
12-06-2016 10:59 AM
Hi @Jamesjia,
I just sent you a private message 🙂
11-21-2016 02:57 PM
Thanks.
How do I contact Moderator?
11-21-2016 02:48 PM
You probably have to contact someone at Public Mobile. It seems something is messed up with your account and preventing call forwarding. They will get it sorted out for you.
11-21-2016 01:42 PM - edited 11-21-2016 01:44 PM
I tried the normal way. It didn't work.
Then I tried the following method:
the error message is:
Call forwarding unconditional coneection problem or invalid MMI code.
11-21-2016 01:15 PM - edited 11-21-2016 01:17 PM
Try the codes listed here to set it up if your phone won't do it using in the settings.
These codes look like they line up with the Telus star codes so here's an explanation on what each does.
http://www.telus.com/en/bc/support/article/call-forward-mobile
11-21-2016 01:08 PM - edited 11-21-2016 01:09 PM
Try this..
Below are the generic settings for different phone types:
Android
Phone icon > Settings Menu >Call > More settings > Call Forwarding
Which method did you try?
