Can’t make or receive calls/texts
Scotian97
HI, yesterday I changed my number and my plan is active. After I changed it my phone stopped working. I have tried to report and unreport, on and off, and hard reset. Nothing works. Account shows one number but my phone says another.
21 REPLIES 21
@Jidoo  a écrit :
I still can’t make c
I suggest you to write a message to the moderator...https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and explain what happened to you. Waiting time is few hours to 2 days..be patient..and before a solution if you want you can buy the add-on long distance for 8$ 200 minutes for the important calls..
Jidoo
MJ23
I would suggest contacting a PM Moderator who can quickly assist in resolving this issue.
Thank you,
MJ23
Kandola12
That's good that it was resolved,
@Scotian97 wrote:
Moderators have corrected this. Thank you for the support.
Do you know what they did?
Edit: Nice to see just a couple hour moderator response time.
Scotian97
@Scotian97 wrote:
Reassign date scheduled for feb 14 so I tried to change it this morning. My account displays active and the new number but I cannot connect to the network.
Have you tried this?
Add $1 to your account?
Restart your phone?
Airplane mode on then off?
Reset network settings?
Scotian97
@Scotian97 What does your Self Serve account say? Is it still active?
I am speculating that Next Plus reassigning your number might be the same as porting it out. Did you attempt the number change prior to them reassigning the number?
srlawren
@Scotian97 wrote:
I successfully ported a Next Plus phone number to PM and ran it for a month. I was notified that due to inactivity within app, my number has been reassigned
@Scotian97 I think this is likely beyond the ability of the community to troubleshoot for you.  Please send a private message to the moderator team if you haven't arleady.  You can learn how to do so here: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-to-Get-Help/ta-p/251745
You were trying to port a number from Next Plus that was already reassigned?
You lost the number associated with your account because Next Plus reassigned it?
Scotian97
srlawren
@Scotian97 wrote:
I was running an isp and the server was about to expire so I needed to change before loss of service
@Scotian97 you were running your own VoIP/SIP service?  Is that what you're saying?  I have no idea how/if a port would work from something like that.
Scotian97
@Scotian97, what was the reason for changing your number?  I only ask, as someone a week or two ago thought it was the reason they couldn't make calls, and it turned out they needed to add long-distance calling.
Please explain if you can, more info so we can assist while the moderators are getting to your issue.
@Scotian97 wrote:
Thanks I’ll have to wait for mods
You do not wish to have us try and help you?
Scotian97
@Scotian97 wrote:
Yes. Had it in lost mode for 4hrs and still nothing
By change do you mean you ported a number from somewhere else or just went to self serve and selected a new number?
Just to be sure @Scotian97you click on find your phone after closed your phone??
If yes you will need help from moderator...here
and explain what happened...wait few hours upto 2 days and they will help you to fix your number...
Scotian97
Lieux
Did you try to click on lost/stolen in your selfserve account ...in plan/option...and close your phone few minutes and open it again..and click on find my phone @Scotian97? Sometimes it helped to restart correctly..let us know...
