Can’t call an area code 647 number with my plan
jonathanlo83
I have an phone plan which includes unlimited province calling (Ontario) but I am not able to call  an area code 647 615 #### number. Can the moderator look into this and advise?
11 REPLIES 11
haraldguenther
yes of course
Meow
If you are on $15 province wide plan, I would suggest to switch to $15 Canada wide plan. Same cost, wider area to call (even if you do not need it now, but it might get handy in the future).
@haraldguenther wrote:
I also can not call 647 area code numbers. They can call me, but when I reply or try to instigate a call or text I am forwarded to a message saying that number does not exist. I have tried all possible options with no success. Btw, I have 24 years professional tech support exp. This issue is not at my end. Harry Guenther
@haraldguenther
I would contact moderator team/PM employees to check what is happening on PM's end.
Click on chat icon on right lower corner of website.  Follow prompts to submit ticket for moderator help. It takes usually a few hours for moderators to respond.  Check your inbox for their private message.
@haraldguenther  did you try adding a 1 in front of the area code?  1-647-xxx-xxxx   ?
haraldguenther
DanielleMarie
Can you please log in to your self serve account and see what your payment due date is? If it says 1969 you'll likely need help from the mods. A few people had this problem yesterday.
For info on the mods check here: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/The-Public-Mobile-Moderator-Team/ta-p/...
Or you can open a ticket via SIMon the chat bot here: https://www.publicmobile.ca/en/bc/get-help
Care to say what happens when you try calling the number?
Does it fail? Does it give you a message like sorry number is not valid to call or no long distance?
Yes I have included.
Not sure why you would not be able to call then, maybe try rebooting your phone?
jonathanlo83
dabr
Make sure to add +1 in front of all numbers when dialling.
Jb456
What happens when you try calling it? Does it say any type of message?
To reach a moderator see pic below
