Reply
Re: Can anyone share LTE speed in b.c
I just switched from telus mobile to Public today on my iphone 5s.
I use Ookla speed test app for every wifi network I use and often I will test cellular as well if I suspect service is sub-par.
January 10, 2019
Download:  90.37 Mbps
Upload:      12.11 Mbps
January 10, 2019
Upload:      12.11 Mbps
iPhone 5s only supports LTE Cat 4.  Your speed result there is very good for that.
If you're on an LTE plan at Public Mobile, your current device isn't the best to use to test out the network.  With a newer device, Public Mobile is capable of providing much faster speed results.
On a side note, the speedtest.net app is a data guzzler.  One test can run between 0.5 to 1GB (depends how fast your connection is).  This test uses more data that faster your speeds are.
