Reply
Highlighted
Can anyone share LTE speed in b.c
Hi I used to be with public but switched away. I now need a second line and am thinking about having that on public mobile. But can anyone share LTE speed  in b.c if possible close to new Westminster.
Accepted Solutions
Highlighted
Re: Can anyone share LTE speed in b.c
As @imm1304 mentioned, Public Mobile recently fixed the throttling bug. The speed has been improved alot since then. I am not in the New West but somewhere near there and i got this speed at home. I am sure you won't have to worry about the coverage as long as your phone is fully compatible with Telus network.
@ShawnC13 Is that speed you got after they fixed the throttling bug? It should be more than that unless you aren't connecting to LTE bands.
_________________________________________________________________________
New Here? - Check out Knowledge Base Articles to learn more about Public Mobile.
All Replies
Highlighted
Speed is decent in BC area.   You wont get much LTE speed result as it used up too many data.
You can simply sign up for a short term and test it in your area by yourself, results varies, depends on many variables.
Highlighted
I know I just want to know near Douglas college if possible. Is it useable. I'm going to order a SIM card.
Highlighted
Hey @Harvir_K,
You can expect excellent data speeds in most areas where there is Telus coverage.
Recently, PM fixed a bug that was resulting in slower LTE speeds.  Read the last few pages of this thread where people have reported speedtest results, many of them from BC:  http://productioncommunity.publicmobile.ca/t5/Discussions/Is-Public-Mobile-s-LTE-throttled-vs-Telus-...
Hoepfully someone from the specific area you are interested in will comment sooner or later.
Highlighted
Thanks once my SIM card comes I will bring my second line to public and maybe move my first one here too.
Highlighted
Borrow a sim card from Telus/Bell and test.  The result is the same.
Highlighted
My old sim card might be able to work with public. I will ask a mod when does a SIM card expire.
Highlighted
@Harvir_K
You can check for the cell towers in your area on this map:
https://www.ertyu.org/steven_nikkel/cancellsites.html
PM uses any green (Telus) or blue (Bell) towers. You can also click on the individual towers to see which bands they support.
Highlighted
If the old sim card was already used, then you have 90 days from the day the last plan expired on that sim card.  If more than 90 days have passed, then you can toss it.
If its an unused sim card, it doesnt really expire until activated first.
Highlighted
It's been about 20 days
