03-13-2020 08:47 PM - edited 01-05-2022 09:55 AM
I am trying to activate my SIM. Everything works until the alternate number field. It is not accepted I tried several numbers and used the format correctly
Can someone please assist??
03-13-2020 11:40 PM - edited 03-13-2020 11:40 PM
@Chloe535 Public asks for an alternate number to contact you in the case that they are unable to reach you using your Public Mobile number.
Enter a number that you can be reached at and make sure it's not the number you are trying to port in.
03-13-2020 10:32 PM
messages from two different threads have been merged into one
03-13-2020 10:20 PM
Just put a Random phone number like 7000000111111
03-13-2020 09:34 PM
If this is the porting alternate number then try just activating with a new number to start. You can always port over later.
03-13-2020 09:32 PM - edited 03-13-2020 09:33 PM
@Chloe535 This has to be the most stupid thing. Get your self a TextNow number and use that as your alternate number. You can always change it later. Are you trying to port a Koodo prepaid number? Is this your alternate number? Thanks.
03-13-2020 09:28 PM
@Chloe535 Try 10 digits, no spaces. ###×××####
03-13-2020 09:26 PM
@Chloe535 do you have another number that you can use? You can always change it later from within your self service account.
03-13-2020 09:26 PM
I am just putting in the number there are no “-“ or “(“ or “)”
03-13-2020 09:24 PM
Please assist I cannot:
1) Activate my SIM as it is not accepting my alternate number in the mandatory field
2) Create an account, it says my number is already in use. I tried several different numbers with the same response
Please assist I really want to come on board with Public Mobile!
03-13-2020 09:23 PM
Well I'm confused too then. They've been mucking around with things recently so maybe this has popped up. will13am's link doesn't have an asterisk. I don't have an alternate number on my account.
So I'm not sure what to suggest.
03-13-2020 09:21 PM - edited 03-13-2020 09:28 PM
PM server is expecting a 10 digits number without any "-", "(" or ")" to separate the area code, first 3 digits and the last 4 digits of your phone number.
I am not sure about the activation form. But the port number form only accept 10 digits number for the alternate number.
03-13-2020 09:15 PM - edited 03-13-2020 09:16 PM
@Chloe535 , try clearing the browser cache and starting from the beginning. Just to be sure, I suggest following this illustrated activation guide.
03-13-2020 09:12 PM
I’m very confused. I’m trying to activate my SIM card and in order to do that it asks for a a 10 digit alternate number. It is mandatory with a red asterisk. Each time I try it rejects it. How can I get around this if its a mandatory field??
03-13-2020 09:03 PM
It won’t let me continue without the number
03-13-2020 08:56 PM
@Chloe535 You can add it later through the edit profile link in your self service account. If it helps, its a 10 digit number.
03-13-2020 08:50 PM - edited 03-13-2020 09:36 PM
It's not a required field if you think it's stopping you from proceeding.
Edit: the porting alternate number is required
