03-07-2020 09:43 PM - edited 01-05-2022 09:50 AM
Salutations,
i just bought a SIM card, however, when I try to activate it and start the account and service, it's claiming that it's an invalid SIM card number. I am positive I've put in the right number.
03-08-2020 12:17 AM
@halcyonguitars If you've been referred to a moderator then their help is required to complete your port. If it's the aforementioned koodo or pc mobility prepaid only a moderator can change the number for you. This is because the number us not actually getting ported but moved from one account to another within the prepaid system all shared by koodo, pc mobility and public mobile. (All owned by telus and all sharing the same back end system.)
03-08-2020 12:05 AM
Thank you, I have done so!
03-07-2020 11:51 PM
@halcyonguitars set up your self service account if you haven't done that yet. It gives you a safety net in case something goes wrong with the port.
@halcyonguitars wrote:Thanks!
i tried that but was referred to a moderator...
We'll see!
03-07-2020 11:45 PM
Thanks!
We'll see!
03-07-2020 11:33 PM
@halcyonguitars Now that you have your service all up and working you can port your number over by using the change number feature in your self serve account. As long as it's not koodo or pc mobility prepaid you just need to enter the name on the account, account number and the phone number to be ported.
03-07-2020 11:24 PM
That's exactly what happened, thanks!
I've got a temporary number and the connection works.
03-07-2020 11:17 PM
@halcyonguitars wrote:They tried to activate it in the store, but the system would not accept my visa debit so I bought a voucher...
They said they couldn't activate it until I got the number unlocked from telus to port over to Public. Phone is unlocked now, but when I try to activate the sim it says it's an invalid number...
Maybe try the PM Sim card in the phone to see whether it is already activated by the store.
The vendor was wrong. You could activate a temporary new number without unlock code from Telus.
03-07-2020 11:16 PM
@halcyonguitars , are you sure that they did not activate it in the store with a temporary cell phone number?
@halcyonguitars wrote:Tried on two different computers. SIM came from a little hole in the wall kiosk...
03-07-2020 11:14 PM
03-07-2020 11:10 PM
03-07-2020 09:57 PM
@halcyonguitars you can download the TextNow app and use it over WiFi to make/ receive/ send calls and texts for free to the US and Canada wide. Welcome to PM.
@halcyonguitars wrote:Salutations,
03-07-2020 09:46 PM - edited 03-07-2020 09:48 PM
Did you get to the part to enter credit card details?
If so, check if your card was charged. If it was put sim in and see if anything works. Also try logging into self serve Account if you can't try to create one manually at link below. Only if you were charged on credit card
https://selfserve.publicmobile.ca/self-registration/
If it was not charged. System locks sim card for 50 minutes. Wait one hour clear history and cookie cache and try fresh browser in incognito mode.
Take note. System is having network issues at moment (internet data) not sure if it affects new sign ups activating a sim card....
Don't forget a referral code for a$10 sign up bonus.
03-07-2020 09:46 PM
Website can be finicky. Maybe try a different web browser, clearing cache or incognito mode. Chrome incognito seems to work well with this site.
BTW, where did you purchase the SIM card? Occasionally, SIM cards are not working when sold.
