Reply
Highlighted
Activating data on Galaxy s3 mini 18200N
Hi, I am trying to activate data on my phone. I have followed the instructions and entered the APN information (a few times) and have not been able to activate data. Appreciate anyhelp/suggestions. Thanks.
Highlighted
Re: Activating data on Galaxy s3 mini 18200N
@LMATZ , you likely need to set up the APN on the phone.  Check out this help page.
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-data-on-an-android-phone
Highlighted
Mind a question bombardment? Lol
If not, I'll get the ball rolling by asking an easy one.. are your call/text services working as expected?
Highlighted
@LMATZ if GSMAreana is correct, your phone (https://www.gsmarena.com/samsung_i8200_galaxy_s_iii_mini_ve-6190.php) is lacking the 850MHz 3G frequency.  That plus 1900MHz are required for adequate coverage.
Highlighted
I'm also wanting to know if calls and texts are working. @srlawren said no 1900MHz 3g, but the specs I saw said no 850 either.  If that's right, this phone won't work.
If your calls are working, the phone is compatible. Try APN type of default.
Highlighted
Hi, calls and texts are working but no data. I have inputted APN but no luck. Any idea about what I could do next?
Highlighted
Log into self serve to see if you bave any data left or if it's all used.
Highlighted
Nearly all data is available to use .
Highlighted
@LMATZ
Make sure the APN setting exactly matches the following:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Don't forget to save these settings and then select this APN as the active one.
Could also try Nework reset.  If that does not work, even a factory reset.
Since it is missing the 850 band, your phone might not be ideal for Public mobile.  It also seems not to have any 4G bands.  Data may not work....
Highlighted
Thanks, I have entered the APN details and still no luck. I could previously make calls but now have seem to have lost that ability. Looks like a new phone is in order. Thanks again.
