APN settings
Dimesntreys
Does anybody have the APN settings on hand so I can manually input it? I have an LG phone and would prefer not to do a hard reset.
10 REPLIES 10
MarkDonn
Thanks! This worked for me on my LG V30
APN: sp.mb.com
APN Type: default,mms,supl *
MMS/MMSC Proxy: 74.49.0.18
MMS/MMSC Port: 80
MCC: 302
MNC: 220
APN Protocol: IPv4
APN Roaming Protocol: IPv4
... leave all other fields blank/empty
APN Type "default" is usually good enough for everything - that's why it's the default - some phones explicitly require "mms" to send/receive msg attachments (because of manufacturer's sloppy operating system implementation), some apps rudely insist on "supl" for location/GPS accuracy (because of devs who use outdated code libraries), best to configure these options if they're available but don't worry too much if your device (software) doesn't support them.
mamills
Hi. I tried a factory reset and it still didn't work. Next I googled "Public Mobile apn settings" and the information came up. Hope this helps.
Public Mobile Internet and MMS APN settings.
APN sp.mb.com
MMSChttp://aliasredirect.net/proxy/mb/mmsc
MMS proxy74.49.0.18
MMS proxy port80
9R3W4L
I am supposed to travel to US in a few days, so I have questions about the APN settings.
1. Can I change the APN settings before hand? So as soon as I land there, it will be working.
2. If I do change it before hand, will it affect my service in Canada?
3. Do I need to change the settings once again when I come back to Canada? If yes, what change are those?
Thanks in advance.
Dimesntreys
@Eevenson wrote:
I tried to access it via that web link and the page freezes every time I try to click the LG option. I have an LG G5 and I've set the access point information to that which I saw provided in these posts and it doesn't work.
If anyone can help fix this it would be greatly appreciated.
Factory reset the phone (setting>general>backup and reset>factory data reset) Don’t forget to take a backup of your contacts and such.
Eevenson
Effort
will13am
@Dimesntreys, APN settings can be found on this site.  For LG phones, there is a network reset function.  It does not reset everything, just network related settings.
https://apn-canada.gishan.net/
