APN Settings for Xaomi PocoPhone
Yamini
I am looking for APN Settings for Xaomi PocoPhone. Need help.
7 REPLIES 7
NDesai
@Yamini Can you please take a min to confirm if you were able to get Data working on your PocoPhone F1? If yes, what changes are required?
will13am
@Yamini, your APN settings are fine.  What seems to be the problem?  BTW, please remove reference to your phone number.  It is showing in your screen caps.
austinhuang
@Yamini wrote:
Here are some screenshots, these settings did not work.
Dual 4G doesn't matter tbh
  • MVNO Type is "GID"
  • MVNO Value is 4D
  • APN Type is "default,mms,supl" No spaces
  • APN Roaming Protocol is just IPv4
  • Name is "Mobile Internet" but it maybe doesn't matter
zub1
Try activating dual 4g in both sim cards in sim card and settings.
Yamini
austinhuang
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp... or https://apn-canada.gishan.net/en/apn/public-mobile/
There isn't much difference on APN settings between models.
If this solves your question, please select my reply as Solution!
