04-01-2020 09:25 AM - edited 01-05-2022 10:11 AM
Hello,
I'm calling an 800 number: +1 800 680 0750
And I keep getting this message: 2 UT 1/2 UT 2 - All Circuits are busy. Try your call again later
Please help.
I found a similar topic but it doesn't help: https://productioncommunity.publicmobile.ca/t5/Discussions/2-UT-1-2-UT-2-All-Circuits-are-busy/td-p/...
Best wishes,
Roman
04-02-2020 12:21 PM
If it's an audio conferencing line: I find retrying the call 5-6x usually gets me in. Alternatively: try finding a local dial in number.
04-02-2020 11:37 AM
Thank you!
It's true.
I needed to try several times.
04-01-2020 10:31 PM
Well testing the same number now it goes through. 🙂
You can also try calling their direct number in Toronto +1 416-649-8574 instead of the toll-free number which is more likely to go through. 800 calls usually pass through a few more carrier interconnects that could be at capacity...
04-01-2020 02:17 PM
@roman_mironov wrote:Hello,
Please help.
Best wishes,
Roman
@roman_mironov Unfortunately, all networks are experiencing an overload of people calling because of the current pandemic and that is why you are hearing that message. Most of the time retrying again will get you through. Sorry, there really isn't any option other than to keep retrying until you get a connection, although some users here are recommending to use a voip app like Textnow which allows for free calling/texting over WIFI and there doesn't seem to any issue with not being able to call on it for now.
